It is currently Mon Jun 23, 2025 10:55 am
PostPosted: Thu Mar 23, 2006 6:14 am
I hope this doesn’t bore anyone or have you thinking, “Here we go again”. I am working on my second classical guitar with a Western Redwood Cedar top. I just finished installing the rosette and after putting it through the drum sander and ROS, I am at about .103” to .108.
Generally speaking, is this to thin for a classical top? Yes, I know it depends on many variables, but I am not keen enough of them to know.
Guitars...One's too many...Twenty is not enough.
PostPosted: Thu Mar 23, 2006 6:18 am
I'd say that's not too thin for a cedar top, but I would not go too much thinner either. As you say, a lot depends on the design you're using and what you want the sound to be. Get a look at Dave Hurd's 'Left Brain Lutherie' book for some information on how to deflection test the top. This should help keep you out of trouble.
PostPosted: Thu Mar 23, 2006 8:33 am
My first (and only so far) was much thinner than that. I think it probably ended up at around 2.2mm, or 0.0866", give or take a tenth millimeter or two. It sounds good to me, but who knows how long it'll last.
#2 cracked in half. I'm down to 1.4mm, .055", in spots. It's spruce though. May be ugly, but I expect it to work.
Edit: You know, now that I think about it, my cedar top might be even thinner than that. Maybe in the upper 1mm range...bbeardb38799.6960532407
PostPosted: Thu Mar 23, 2006 9:21 am
Your fine. I go down to about 2.5mm with cedar and traditional bracing and 2mm with lattice braced tops.
